Teac SR-2DAB digital radio, Battery conversion, 12 volts
Error message
  • The comment you are replying to does not exist.
Has anyone converted the above to 12 volts?
I'm hoping the power supply has a single output to enable this.
PushyG
PushyG picture
Hi!
You can download the schematic diagram: https://elektrotanya.com/teac_sr-2_sr-2dab_sch.pdf/download.html
You can see, this radio have 3 AC power and 5 DC power + 1 AC detect line.
You can not transform it to one DC12V power line.
Gabor
Multi Multiplikátó
Multi Multiplikátó picture
Isn't so bad. Needs an 5V, could be produced by a step-down DC/DC converter, needs 14V, could produced by a step-up DC/DC converter, we can keep the U101 to make 8V supply, the inlet (pin1) of U307 could be wired to outlet of U101. The AC outlet ("AC/DC DET") is rectified, too, so the circuity will accept some DC voltage there as the AC, too.
So it could be modify to 12V DC by adding two cheap, chinesee made DC/DC converters.
