TECHWOOD TK3216HD12B TV NOT TURN ON BUT I HAVE SOUND
Hello
I have 1 techwood tk3216hd12b TV.  I changed the 2 led ramps.
 On the vestel 17ips62 board, I changed the sr5100 and uf5402 diodes.+ the 68mF 100V condo and still no image.  Than the sound.
 If I put a ramp of LEDs on the 2, (inverting one after the other to check that they are good), the ramp lights up, If I put the 2 >: nothing.. I have a voltage in charge of  33V5 at power board output;  I think there should be good + for the 2 ramps to light up.  Could the power board be out of order?  the T-con card which would be faulty?  OR, what else???  (I lit the screen from the inside, and there is an image that appears) thank you
