tecnics rs-tr155 cassette not playing
Technics cassette player rs-tr155 .tape starts and stops. What is the problem.
PushyG
PushyG picture
Hi,
Are fwd reel rotates, when your start the playing?
G
Ted stooksbury
Ted stooksbury picture
yes, the fwd reel rotates
PushyG
PushyG picture
Hello,
There may be a problem with the cassette presence sensor (HALF switch at the top edge of the cassette). If it has a contact fault, it will lose presence due to vibration.
This error can be caused if the drive belt is broken. In this case, it cannot transmit the correct torque to the head movement wheel and throws it back into STOP mode.
The rotation sensor (HALL) sensor may be faulty.
And the transmission gear may be faulty, because this is a typical source of error. The wheel marked RDG5772ZA loses its teeth and the drive is interrupted.
G
