Some one can tell what logic Level for 60Hz line? Datasheet don't mention ...
Best Regards
hi
Hi! https://www.eleccircuit.com/wp-content/uploads/2012/09/cheap-digital-tim... Low level (VSS) for 50HZ, and 24H display. Regards,
Jacint
Tanks.
Didn't notice it was mention on schema .... Need to pay more attention ...
szia: ez TMS3450, ennél 50Hz NC, 60 Hz ground, a jól látom
VSS is 10V for 50Hz PIN26 = VSS
Earth center tape ? Low Level -10V?
Hello:
https://pdf1.alldatasheet.com/datasheet-pdf/view/86980/TI/TMS3450NL.html
Tank You.
hi
Hi!
Regards,
Jacint
Tanks.
VSS is 10V for
50Hz PIN26 = VSS
Set to 50Hz and Set to 60Hz didn't Change the divider.
Earth center tape ?
Low Level -10V?
Hello:
Tank You.
