Toshiba 32C3035D tv, no backlight
Hello there!
I am a senior electronics technician, retired already, and i need your help in order to repair a TV, as shown in the subject title, which belongs to a close friend of mine.
I have already downloaded the zipped file, but I cannot open it, while I am an "old timer" technician, not familiar at all with computer technology, software issues etc. Therefore, all I need is its schematic alone. I wonder if you can do me this favor, sending it to me in a pdf form. I have spent many hours trying to follow your instructions in order to read the downloaded one, but in vain, with no result.
I stopped troubleshooting it, after many hours searching in blind.
The problem it has, is that the backlight lamps are not lighting up. The power relay clicks on, but after a while it turns of. I checked all the voltages. Everyone of them is there, except the "order" POWER_LCD", which doesn't show up. It seems that there is a short circuit there, at its source, but it is impossible to find where it comes from and I am afraid that the source is the microprocessor itself. Anyway, at the destination point of this "order", at the pcb which contains three small dc/dc converters, I found an smd transistor with all its electrodes open to each other. But after replacing it, still nothing happened, and then I saw that the "order" does not appear any longer.
Next, i took a sample of the switched 5,1V, having it isolated by a 1N4148 diode and using a current dropping 1kOhm resistor, in order to see what happens. The non operating dc/dc converter now turns on, but still the backlight lamps are not. This is the point I have stopped. I forgot to mention that the two big electrolytic caps (820μF/35V) on the inverter pcb were found bulged and I had them also replaced. I didn't find anything else problematic there through my static measurements.
Any help will be appreciated!
Thank you in advance!
Paris
Shizo
Shizo picture
Hi
Add model name of inverter board and  power board.
