hi I have a toshiba 37x3030D with a sudden power problem, no smoke No stand by light , the TVs looks dead but the power supply PE0252 looks to be working and has 5v on pin 8 , No power on pin 6 power sig , pin 1 inv dose not have 24v,& pins 4'5 Audio vcc both have No power as the relay is no pulling in I guess, The other connector has 18v on pins 4'3. & 47volt on the 40v pin 1.
This feeds board PE0253 and then to main board PE0250 which in turn feeds the power on momentarily switch pcb board & standby LED board.
I wonder what feeds the power sig pin 6 - 5v?
I did try bridging the power supply relay with no effect. Probably back lights but haven't had much time on it so looking for the best test points or diagram to work through. Help before the wife chucks it.
Thanks dave
