Yaesu FT-2400 hard reset
Error message
  • The comment you are replying to does not exist.
After looking in the manual, it says that a processor reset can be done: perform a hard reset
by removing the top cover, and shorting across the split solder pad on the circuit board exposed
on the inside of the front panel, just behind the top left corner of the display. Then hold D/MR While
switching on.
Problem is, I cannot tell what 'split solder pad' they are referring to in order to complete the process.
A picture would be very helpful. A video even more so.
Thank you in advance.
Chromehero
BTS_szerviz
BTS_szerviz picture
http://radioaficionados-cba.blogspot.com/2019/03/liberar-radio-yaesu-ft-...  solder pads (jumper pads) Remember whitch PDs are locked originally!!!!!
https://www.qsl.net/kb8qeu/ham/ft2400.htm schematic
