Hi,
I am experiencing a specific problem on my gloriosus DSP A1.
When I switch it on the right surround channel is mute and some times also the left surround channel and (one time also the central channel).
If I encrease the volume louder and louder the mute channel start to sound with a bad initial "crack sound". After that the channel works fine.
I suppose it's a cold welding problem or an electrolitic condenser problem. And it is affecting the 3 effect channels only.
How can I fix it? Thanks in advance.
First make sure if ALL channels are mute sometimes. In your case, it seems relays problem due to a layer of black oxide called
Ag2O affecting the contact conductivity. Open ALL speaker relays, removing black oxide by glasses repairing screwdriver.
If I encrease the volume louder and louder the mute channel start to sound with a bad initial "crack sound". After that the channel works fine. Time needs for oxide to allow
electrical signal to pass through if an oxide layer is not too thick.
Thanks a lot. I'll do my best to identify the speaker relays in the service manual and to clean them.
