Hi, I need a circuit diagram for a Zanussi FL 828 washing machine as the ON switch is broken so I want to bypass that to put a separate switch in place of the broken one. It is impossible to remove the front panel so I could use the connections on the Circuit board.
Any help in this regard would be most appreciated.
Thanks Don
See if it helps
https://elektrotanya.com/zanussi_fl828al.zip/download.html
Hi, Thanks for your reply however I already had that download but it didn't show the actual wiring at the timer. Also I wanted to
know how to take off the front panel but the knobs would not come off even though I followed the instructions in the manual.
I tugged at it so much that now the timer cogs are slipping and wont engage
Its a pity because this is a great washer up until now and its a shame to dump it. Thank you
Donal
