Az említett modulon az LVDS csatlakozó mellett felrobbant egy smd ic. Ami olvasható rajta: ...4801, az eleje hiányzik, ha volt előtte valami. Erre a számra több különböző funkciójú ic-t találtam, így valószínűsíthető, hogy volt előtte még valami. Az ic pozíció száma: U24 Tokozása SO-8.Doksit nem találtam rűla. Köszönöm a figyelmet!
Dear all,
this TV, Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
The problem started to occur suddenly, during a video conference. It was switched on with the remote control, continued to work for a while and then switched off again.
The room technician changed the power cable (?), the HDMI cable (??) but the problem of course remained.
I asked if it changes anything by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60’ which is not easy to handle) to the lab and asked me to check it.
I still have to open it up, but I don't have the schematic diagrams and should proceed by trial and error, although I imagine a problem with the power supply stage.
How do you suggest I proceed, since I don't do TV but RF ?
Thank you for any help,
Best
Maximus
Hisense LED TV 55 INCH
MODEL LEDN55K20DP
MAIN BOARD RSAG7.820.5511/ROH
PANEL Hisense HD550DF-B31(010)/S1/FM
T-CON 14Y_EF11_TA2C2LV0.1
N55 SPI Flash MX25L3205
Hello,
I have this LCD TV which has a very white screen, the picture is visible. I could not find any fault on the CCFL Lamp inverter and was suspecting the T-Con panel of failure. The T-con panel is integrated in the control board. What i did is using "freeze it" cold spray i sprayed one of the IC's and it cured the fault. Perhaps the IC needs to be replaced. The part number is AS15-G. This component is not available for purchase in south africa and i would need to import it from china. This part is a LCD voltage buffer.
Regards
Angelos
