NEUTROFON OKTODE SUPER-55 1934 SCH
Type: (PNG)
47.6 KB
Looking for similar neutrofon manual?
    NEUTROFON OKTODE SUPER-55 SUPER55 1934 SUPER 55
Monacor_PA_940_power amplifier_240w A végfok nem működik. Előfok jó. Tápok rendben.
Üdvözlök Mindenkit!
Nagyon megköszönöm, ha valaki tud segíteni.
SONY CDX-M700R tuner rész!
Sziasztok! Ennek a sony-nak süket a rádió része, még sistergés sem hallható. A cd kifogástalanul működik, lejátszik mindent. Milyen feszültségeket kéne tudni mérni a tuner lábain?
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Jbl SUB 178 auto on off probléma.
Sziasztok! Van nekem egy Jbl sub 178 am . egyszer csak nem működött az automata on off funkció. Ha nincs jel ki kéne kapcsolnia. Most bekapcsolt állapotban maradt. Fent van a tanyán a kapcsolási rajza de sajnos nem találom a hibát. Segítséget szeretnék kérni,hogy merre keressem a hibát. Köszönettel Árpi
