Hi!
I will not forget to defend Bálint, but he is right in that we cannot help you that way.
First, you should pull down a button to determine whether the shaft of the potentiometer is D-shaped or star-shaped.
Hifista.
Thanks for the polite reply ....
I m not lazy ..
Thing is ,that i must have the components before i take it apart and i have very little time to repair it....
It works all day and i cant take it with me to open it up at night and return it in the morning....
So did i answer your remark "lazy" ....???
If you can help you are more than welcome to provide to me the info that i need, or else please the comment column clean so other tech guys can help me ....
Thanks have a nice day ....
P.S. the pdf files do not have list part inventory, i checked before i asked .....
Hi!
Hifista.
hello:
ha lusta vagy szétszedni és megnézni, akkor innen kibogozhatod
https://elektrotanya.com/showresult?what=Phonic%20deluxe%20740&kategoria...
I m not lazy ..
