To unlock the USB port on the LG 22LH2000 TV for using a flash drive, you’ll need to perform a service menu modification, as this model originally has its USB port disabled for media playback. Here's a general guide based on community-shared instructions from ElektroTanya
⚠️ Important Notes:
This process involves accessing the service menu, which is intended for technicians. Proceed with caution.
Incorrect changes can affect your TV’s functionality. Only change the settings mentioned.
🔧 Steps to Unlock USB Port on LG 22LH2000:
Access the Service Menu:
Use your LG remote and press the following sequence:
MENU → MENU → 7 → 7 → ENTER
(Some models may use OK instead of ENTER, or a different sequence like MENU → 0 → 0 → ENTER.)
Navigate to the “Tool Option” Menu:
Once inside the service menu, look for Tool Option or Tool Option1.
Modify USB Settings:
Find the setting labeled “USB” or “DivX”.
Change the value from 0 to 1 or 2 depending on the available options.
1 usually enables basic USB functionality.
2 may enable DivX playback support.
Save and Exit:
Press Exit or Return to leave the service menu.
Power off the TV and restart it.
Test the USB Port:
Format your USB flash drive to FAT32.
Load compatible media files (e.g., MP3, JPG, DivX AVI).
Plug it into the USB port and check if the TV detects it.
Hello,
⚠️ Important Notes:
Save and Exit:
Test the USB Port:
