Best way to keep track of lithium battery levels?
6 posts / 0 new
kasuo
kasuo picture
I’m running a small DIY project with 18650 cells and I don’t want to over-discharge them. Right now I just check with a multimeter every so often, but that’s not really convenient. What’s the simplest way you guys monitor lithium battery levels in real time?
proba
proba picture
lizakl
lizakl picture
Hi!
BMS(Battery Management System) circuit need.
kasuo
kasuo picture
I stopped using the multimeter method because it was too much hassle. I ended up adding a lithium battery voltage indicator with LED bars that show the charge level directly. It picks up tiny voltage changes and updates quickly, so now I can glance at the lights and know roughly where the battery’s at without pulling out any tools.
lizakl
lizakl picture
Well, the BMS is the best method and not expensive! :-)
Shizo
Shizo picture
Hi
BMS automaticly disconnect battery when  voltage drop to 2.8V, if you don't use your device large time and voltage drop to 2V, battery will be damaged permanently and cannot charge it again.
