UPDATE:
Note: This Model and CUC220, CUC720 almost identical
My family b. this TV in 80'
And worked ~15 years
In 90' Black screen ... with Pot. in 100% Brightness, Contrast.
In the end 90' puff doesn't work at all.
Someone try repair but ... the same black screen.
They reported ... try fix and get > Brightness
In past 6 months, I repaired and new life come from the set, but now we get too much Brightness
In your opinion ... the person try Adjust ... fix what?
ABL - Automatic Brightness Limiter setup, regul.?
R2533 R2538?
Thank you for your comments, info.
Ruy
Please your comments:
Brightness and Colour Pot. -> OK
But Contrast Pot.: I can' rise ... NO FOCUS and
washed out -> I only see a Blank RASTER.
Best Regards,
Ruy
__________________________________________________________________________________
ORIGINAL / PAST MSG
Hi,
Super Color A 7100
The other sub-models in pag.1 - pdf
right bottom
elektrotanya.com/grundig_cuc120.pdf/download.html
The screen is black ... and we notice from time to time (when the image is very brig.) some small part of image.
Very few dots.
I tested the G1 2X V, G2 5XX V, Heather - G and J Volts in the neck of Cinesc.
Power Supply I tested +A 115 V, +C 200 V , +B 12V, +M 19V
In Pag. 6 - SSB and SB? T2533
Thank you,
Ruy
Work with servers - OpenBSD, NetBSD, FreeBSD, Linux.
Love Oscilloscope :-) , Repair, Satellite Dish, Multimeters.
Have a Big Satellite Dish farm.
