Hello everybody!
I have at the moment a electronic module of a washing machine, and i can´t identify some SMD components to replace.
As you can see on the attach file, there is a SMD with the code 6A. i can´t find this, and i don´t have the electronic schematic.
If anyone can help, i apreciate.
Thank you very much.
Nelson Ferreira
search: smd code
second result: The smd code book
click
search: 1st character of code - "6"
click
center of that page there are some search results what you are seeking
if there is in your pcb a good 6A component, you can measure that and figure out which one is the right one from these search results
that's it all.
