Bom dia.
Tenho um multimetro marca Metrix modelo mx462h, o qual tem o comutador rotativo queimado.
Pergunta : onde posso obter este comutador ?DJEKF
Good Morning.
I have a multimeter brand Metrix model mx462h, which has the rotary switch burned.
Question: where can I get this switch?
ck
Hi,
I remember, that Cetralab had such same switches, these is a type of 2x6 stages, 2x 7pins on cca an inch distance...
Maybe on these way...
Hi!
Try to buy a broken one, eg LCD broken. The microcontroller not damaged?
Hello, the Google search shows a vintage analog multimeter (from radiomuseum.org), and the last picture shows the rotary switch. Maybe some company still makes it.
https://www.radiomuseum.org/r/metrix_multimetre_mx462h.html
Ja, hogy nem mai gyerek, nem is néztem.. Ebből ritka a törött LCD :)
