Zanussi FL828 broken ON switch
Hi, I need a circuit diagram for a Zanussi FL 828 washing machine as the ON switch is broken so I want to bypass that to put a separate switch in place of the broken one. It is impossible to remove the front panel so I could use the connections on the Circuit  board.
Any help in this regard would be most appreciated.
Thanks Don
ityvity
ityvity picture
Donal Wyer
Donal Wyer picture
Hi, Thanks for your reply however I already had that download but it didn't show the actual wiring at the timer. Also I wanted to
know how to take off the front panel but the knobs would not come off even though I followed the instructions in the manual.
I tugged at it so much that now the timer cogs are slipping and wont engage
Its a pity because this is a great washer up until now and its a shame to dump it. Thank you
Donal
