Yamaha PSR-GX76 no power from DC socket
Hi have a psr-gx76 for years, Recently the DC socket that holds the power jack has lost continuity. Also the jack housing wobbles. Is there a way to repair the housing or re-solder the housing to the base. Have looked the device over; seems like a lot of screws to remove. Will the cover release easily once the screws are removed.
Thank You,
Chuck
