I recently bought an Accurate 157 tube tester. I wanted to check some 6EU7 tubes but I find that the tester manual doesn't list that tube. Anyone? Add new comment Comments 2023, June 9 - 08:55 #517662 torokj 14 years 11 months Hello Steevo468, The 12AX7 has similar parameters as 6EU7,but different socket pinout. Make a socket adapter. Good luck! TJ 0 2023, June 9 - 08:57 [torokj: #517662] #517663 TonyStark 3 years 1 month*** Ismétlés a tudás anyja. 0 2023, June 9 - 09:06 [TonyStark: #517663] #517665 torokj 14 years 11 months Take care ,the heating is different!The 6EU7 double triode has COMMON filament,the other separated.(Serial mode 12V,Paralel 6,3V) 0 2023, June 9 - 08:51 #517661 TonyStark 3 years 1 month*** Hello Steevo! The 6EU7 is the same as the ECC83/12AX7 electron tube, only the wiring is different. Make a conversion socket for it, and you can measure it based on the mentioned tubes. Regards: Tony 0
Hello Steevo468,
Good luck!
TJ
Hello Steevo!
Regards: Tony
