AC mode and NCV mode do not work in Uni-T UT210E current clamps. The display shows OL. Add new comment Comments 2024, September 15 - 11:10 #548453 hcs 14 years 11 months You can download the schematic from here: https://elektrotanya.com/uni-t_ut210e_schematic.pdf/download.html Inputs has protection devices. Check pnp/npn transistor pairs, ptc devices if the other functions ok. If the main chip is failed, you can find a replacement and maybe firmware for it. This clamp meter is a popular and well documented instrument. Good luck. 0 2024, September 15 - 10:43 #548450 lcsaszar 10 years 2 weeks* DC voltage and clamp current measurement is OK? 0
Good luck.
