Hiba a következő.
Tévé bekapcsol főkapcsolóval stanby led világít de ha megpróbálom a p+ gombal vafy távirányítróval bakapcsolni akkor villog a led elől folyamatosan és csak a stnby táp megy a másik nem indul.
Megnéztem a 8 voltokat meg vanna e de meg vannak akkor ara gondoltam biztosan a digimodul halt be de nem mert szereztem bele egyet de nem jött be .
Valaki mondta sorkimenős de azt nem veheti észre hiszen nem índítja el a főtápot .
Hi everybody,
I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board.
What I have tried…
Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate.
And here comes what is not clear to me.
1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode?
2. Can I somehow check if the PSU is working? May be by activating some pin?
3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?....
What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms.
The service manual is on this link:
http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html
Thanks Martin
Üdv.Mindenkinek!
A két 47uf-ból(2515,2523) az egyik pupos volt,kicserélve beindult.Megcsináltam az átalakítást:1502 - MP63 biztosíték (630mA)átkötve,
7505 - BC548B cserélve BD139-re,
2511 - 22uF cseréje 470uF-ra.
Pár óra járatás közben 3908(2,2ohm)leég ,vízszíntes csík.Kicserélve 7904(BD 243-ra),7903,3908,2904,2905,2903,2905,2906,2902,2916.Most megy,kép ok -de a hűtődorda amin a sorvégtranzi,7904 és 7903 van nagyon forró(2-3mp-ig bírja a kezem).Ez a normál állapot vagy valami baja lehet még ami miatt ennyire melegszik.A sorvégtáp a 2515-ön mérve 153,7v ezt,hogy lehetne 150v-ra beállítíni-egyáltalán érdemes vele foglalkozni vagy ez még belefér .Köszönöm a hozzászólásokat.
Üdv.:István
Egy 14 HT 3154/01 tipusú, (CH 14 HT3304/01 EU) kis TV Hotel üzemmódban van. ha jól értelmezem a leírásban, a feloldáshoz kétféle távirányító kellhet (standard, ill. a High security üzemmódtó függően). A hozzávaló eredeti, ill. utángyártoot (pl. IRC81543) távval ezek szerint nem lehet belépni a menübe?
Köszönettel
