PHILIPS HB554-A SOLARIUM
HOUSEHOLD - SERVICE MANUAL
215.0 KB
HOUSEHOLD
PHILIPS HB554-A SOLARIUM service manual (1st page)
Preview of PHILIPS HB554-A SOLARIUM [1st page]
PHILIPS HB554-A SOLARIUM service manual (2nd page)
Preview of PHILIPS HB554-A SOLARIUM [2nd page]
    PHILIPS HB-554A SOLARIUM HB554A HB 554 HB554 HB554-A
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HR8345 porszívó motor tengelye szorul (Nincs megoldva, de selejtezve igen!)
Üdv Mindenki! A fent nevezett sajnos komoly hangot produkál és egy kis szaga is van, persze lehet csak az erőlködéstől van. Szétszedtem és azt tapasztaltam, hogy a motor egyik irányban megszorul,a másik irányban szabadon forog, de recsegős, sercegős hangot ad ki a szélkerék/szénkefe oldali csapágy felől, aminek okán gondolom, hogy vagy belekerült valami, vagy a csapágy adta meg magát. A szélkerékburkolatot leszedve és a szélkerékre állítva, majd oldalirányba megmozgatva kismértékű kotyogás hallatszik. Ebből következtetve csapágycsere esedékes lenne. Csakhogy! Sem a szénkefét, sem a forgórészt nem tudom kiszedni, mert a motor összefogató csavarjai a szélkerék felől vannak becsavarozva. A motor felépítménye kísértetiesen hasonlít a HR8731-HR8978 típusú porszívó motorjához, már amennyit láttatni engedett a tanyán található SM. Sajnos a szélkerék felől nincs rögzítőcsavar, hanem valami lemez van a tengelyre préselve, így azt nem tudom levenni és ellenőrizni, illetve cserélni az alkatrészeket. Igaz ugyan hogy már majd 20éves lesz, de szeretném megmenteni az enyészettől, mert már szinte családtagnak számít. :D Van-e a szétszedésének, majd újbóli összerakásának valamilyen trükkje? Várom építő jellegű hozzászólásaitokat és tanácsaitokat. Köszi
Philips GC 4630 vasaló nem melegít (megoldva)
A másik....
Relé kocogtatásra indul, tehát a relé rossz.
De ez meg ki van öntve, köszönjük szépen :(
Philips Senseo kávéfőző vezérlése /Megoldva/
Szevasztok! Vásároltam egy Philips Senseo kávépárnás kávéfőzőt. Egyetlen bajom van vele, hogy egyszemélyes kávét nem tudok vele csinálni. Túl sok vizet ad a 7 gr kávéhoz. Ezt szeretném megváltoztatni. Sikerült letöltenem a gép szevíz könyvét, de abban a vízszivattyúhoz csak egy "vezérlőegység" csatlakozik. Mielőtt szétszedném, érdeklődnék, foglalkozott e már valamelyikőtök hasonló géppel? Pontosabban az érdekelne, hogy milyen időkapcsoló van a vezérlőegységben? Egyszerű RC tag, vagy valamilyen PIC. Bár az utóbbi sem lenne gond, ha vissza lehet olvasni a tartalmát. Ebben kérném a segítségeteket, mert feleslegesen nem szeretném szétbontani. Üdv: Gyula
