Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Tisztelt Kollégák!
A fenti készülék bekapcsolás után szól, időnként pattanás hallható a hangszórókban és elnémul.
A hangerő állítása vagy állomás választó gomb átváltásakor megszólal -vagy nem.
Utóbbi esetben teljes hangerőre tekerve az enkódert, halkan hallani a rádió hangját.
Van, hogy bekapcsolás után hibátlanul működik egész nap.
A CD esetén a pattanás után is elhallgat, de kis idő után error-t ír.
Rajzom nincs. A fő és a kezelő egységben található prociról nem találtam infót.
Aki esetleg találkozott ilyen hibával kérem segítsen mit nézzek át, mi okozhatja a problémát?
Köszönöm az önzetlen segítségeteket.
Üdv. Galibali
Ez volt az előzmény.
Sajnos újra elő jött a probléma. Összerakás után három napig éjjel - nappal ment a készülék. Örültem végre jó. Kikapcsoltam, áramtalanítottam a
készüléket. Gondoltam egyet másnap és bekapcsoltam. Ugyan azt produkálja, kis idő után pattanó hang és elhallgat.
A TEA6880H processzor 35-ös lábán normál működés alatt 4,2Volt mérhető, oszcilloszkópjel nincs.
Hiba esetén a feszültség leesik 2,8Vol-ra és 8,0Voltos 0,5 msec- os állásban fűrészjel indikálható.
Mivel nincs sok ismeretem a processzorok lelkivilágát illetően, kérdezném Tőletek, hogy egyértelmű processzor hiba vagy lehet más is.
Csatolom a TEA rajzrészletét amin jelöltem a 35 -ös lábon mérhető jó és rossz állapotú feszültségeket és a néma állapotban megjelenő oszcilloszkóp adatait. Mint a rajzon látható hiba esetén a vonal fölötti rész letiltott, kimenő jel nincs.
Az enkóder vagy bármelyik programváltó gomb megnyomása után újra szól a készülék.
Kérem segítségeteket.
Köszönöm.
Üdvözlettel, Galibali
Ötleteket kérnék, hogy mi lehet a következő alkatrész egy autórádióban:
+5V a bemeneti feszültség
Kimeneti feszültség ismeretlen, de talán 3V3
A feliratból annyi maradt hogy: AM
Tokozás: SOT-89
A középső láb (forr fül) a kimenet !
A jobb oldali láb van +5V tápfeszen a bal oldali testen, a középső láb a kimenet.
Egy memória mellett van, ezért tippelek a 3V3 -ra !
Köszönöm !
István
Megoldva: AMS1117
Egyik ismerősöm keresett meg ezzel a cd-s fejegységgel. Valami bolhapiacon vette az Alfájához - hogy kicserélje a magnós rádiót. Sajnos kódot kér, és azt nem adtak hozzá.
Elvileg egy 24c08 -ban van a kód, de nem találok hozzá dump-ot vagy leírást hogy hol van a kód a memória tartalomban.
Ezt inkább az autó Hi-Fi-hez tenném, bár az ilyen bolhapiacos dolgok nem egészen korrektek!
Mint kiderült az eeprom írása nem hozhat eredményt, a kód kalkulátorral lett kiderítve.
Mindenkinek köszönöm a segítséget!
