START 21M11
TV - EPROM
309.0byte
EPROM
Looking for similar start manual?
    START 21M11 21 11
Philips 25pt5324/58r wont start
My old TV has just broke a day ago, and when i try turning it on, relay is clicking and tv is not starting. I have heard that it probably has magnificying transformer broken.
STARLIGHT 24DM3500 mainboard TP.MS3663S.PA671 ,restart
Hello, this small tv is equipped with mainboard TP.MS3663S.PA671 ,25Q64 flash SPI ,display V236BJ1-P01 Rev. CB When it starts, it restarts, sometimes it doesn't "leave" from st.by, so maybe we can find an update software on usb (or dump for 25Q64). Thank you
Samsung Slim Fit HD Ready restart
Hello! Van egy Samsung Slim Fit HD Ready 82cm televizió. Ha "hideg"-en be van kapcsolva akkor többször újraindul. Bekapcsol kb 3secre majd ki, ezt csinálja 2 percen keresztül. Régebben egyszer - kétszer kapcsolgatott ki be, de most már 2 percig csinálja után semmi baja. Kis üzemelés után kikapcsolva és újra bekapcsolva teljesen jó, nem indulgat újra. Üdv, Zsolt
led tv PHILIPS 52PFL8605K/02 șasiu Q551.1E LA software update pkg .The TV starts, stops and restarts continuously
Hello! I would be interested if you could find an update software format "pkg" for this TV. From what I searched, I only found upg. Thanks!
