Manufacturer: Panasonic
Type: TX-L42ETW5
Chassi: LA35
Hello everybody,
I could determine or measure the following with the device:
Device does not start anymore, stand-by LED lights red when device is plugged in and flashes red as soon as an IR command (key press) is sent via the remote control. Voltages of power supply STB 5V and signal LCD_TV_SUB_ON come from A-board. Power supply starts, supplies P15V and SUB1.1V, 1.5V, 1.8V, 3.3V, 5V, HDMI3.3V and USB5V are generated on the A-Board (stand for about 2.5 seconds). Then signal LCD_TV_SUB_ON goes low (voltages go away to STB 5V) and after about 2 seconds back to high (endless). What is missing is the voltage PNL12V which is switched on by PANEL_VCC_ON2. PANEL_VCC_ON2 always has a low signal and does not change its state. Power supply also provides for the 2.5 seconds the 24V for the backlight. Clocking of LCD_TV_SUB_ON starts immediately after plugging in the mains plug (also without IR command). SOS error code is not output. The over-voltage circuit in IC 5000 pin 7 also does not respond. Attached is the timing diagram from the technical training of Panasonic where I have drawn until when the boot process behaves normally.
In my opinion a mistake on the A-board? Does anyone have a tip?
greetings
Andi
Hello, this small tv is equipped with mainboard TP.MS3663S.PA671 ,25Q64 flash SPI ,display V236BJ1-P01 Rev. CB When it starts, it restarts, sometimes it doesn't "leave" from st.by, so maybe we can find an update software on usb (or dump for 25Q64). Thank you
Hello! I would be interested if you could find an update software format "pkg" for this TV. From what I searched, I only found upg. Thanks!
Van egy Sony kdl-55w955b, amely problémákat okoz.
Körülbelül 15 perc működés után 5 percenként újraindul. Egyszer leállt az indítás és a piros LED 8-szor villogott.
Érdemes megjavíttatni? Ismertek ilyen problémák ennél a modellnél?
