START 21T29-1-
TV - EPROM
546.0byte
EPROM
Looking for similar start manual?
    START 21T291 21 291 21T29
Restart Sony KDL-55w955b
Van egy Sony kdl-55w955b, amely problémákat okoz.
Körülbelül 15 perc működés után 5 percenként újraindul. Egyszer leállt az indítás és a piros LED 8-szor villogott.
Érdemes megjavíttatni? Ismertek ilyen problémák ennél a modellnél?
led tv TESLA 32S367 BHS Start with the TESLA logo, stop and restart continuously
Hello! At the start of this TV, the TESLA logo appears, it stays on for a while after which it goes out (the backlight goes on) and the logo reappears and the issue is repeated. I changed the MX25L1605 flash memory loaded with software found on a Russian forum, but nothing changed.Someone has the appropriate usb update software ?
It is equipped with : Mainboard : 5844-A7N01G-0P30  VER 00.07. On a white label: SJX-QC JX11-11
On the other: 17C0005M01237
Display : SDL320HY(CD0-720)(14)   REV : R1
                                                    MSDL320HYCD07201481FHA1763
                                             Type : ST3151A05-8
                                              CELL: TA810162BA07
Thanks in advance!
Sansui lcd chassis B.FL.MG04-5431 model sv-3050lcd take long to start and shuts down after 20 sec.
Hi,i have this sansui lcd sv-3050 that i am fixing if i power it on it takes some time to light up and if it manages will shut down in 30 secs.i have changed some caps(power supply)which were bulged.i am suspecting the inverter board (dafron v144-48v1448.001/f)is there a way to bypass or remove the protection on the inverter board and ic it advisable?
Philips 25pt5324/58r wont start
My old TV has just broke a day ago, and when i try turning it on, relay is clicking and tv is not starting. I have heard that it probably has magnificying transformer broken.
