Hello!
Van egy Samsung Slim Fit HD Ready 82cm televizió. Ha "hideg"-en be van kapcsolva akkor többször újraindul. Bekapcsol kb 3secre majd ki, ezt csinálja 2 percen keresztül. Régebben egyszer - kétszer kapcsolgatott ki be, de most már 2 percig csinálja után semmi baja.
Kis üzemelés után kikapcsolva és újra bekapcsolva teljesen jó, nem indulgat újra.
Üdv,
Zsolt
Hello! At the start of this TV, the TESLA logo appears, it stays on for a while after which it goes out (the backlight goes on) and the logo reappears and the issue is repeated. I changed the MX25L1605 flash memory loaded with software found on a Russian forum, but nothing changed.Someone has the appropriate usb update software ?
It is equipped with : Mainboard : 5844-A7N01G-0P30 VER 00.07. On a white label: SJX-QC JX11-11
On the other: 17C0005M01237
Display : SDL320HY(CD0-720)(14) REV : R1
MSDL320HYCD07201481FHA1763
Type : ST3151A05-8
CELL: TA810162BA07
Thanks in advance!
Van egy Sony kdl-55w955b, amely problémákat okoz.
Körülbelül 15 perc működés után 5 percenként újraindul. Egyszer leállt az indítás és a piros LED 8-szor villogott.
Érdemes megjavíttatni? Ismertek ilyen problémák ennél a modellnél?
:taps2:
This is a LCD TV brand EMERSON, model LC320EM3F and is completely death.
At first revision, we detected some bad components in the switching power source:
Switching MOSFET K10A50D, RESISTOR 0.19 Ohm, 2W, transistor switching controler 2SC5344, Zener Diode 1ZB36 (36V) and the 4A fuse.
I had the SM of LC320EM9 model, so, the values of the components are different.
I replace them all twice and they always broke again! FRUSTRATING!
Then I realyze that changin the values nearly to the LC320EM9 model, I would obtain better results (see FILE ATTACHED)
I replace the 0.19Ohm resistor by a 0.39Ohm, maximizing the pulse received for the control transistor, for that purpose, also changed the 2.4KOhm resistor for 5.6KOhm. The switching MOSFET used was IRF640 replacing K10A50D, and transistor 2SC5344 was replaced by 2N5551. Finally we add a Zener diode not included in original board (marked with blue circle) limiting the colector voltage and gate voltage to 26V.
For short, when we connect the power cord, every thing was fine, except than voltages at secondary of main transformer, was only 3.2V DC in all rectifiers.
Found a diode in short-circuit (circled in red), replaced it and BINGO!, the TV return to live again!!!!
I Hope it serves as a nice experience for the future.
