UNITED MOTORS SERVICE-DELCO 601177, EARLY CHEVY SCH
188.0 KB
Looking for similar united manual?
UNITED MOTORS SERVICE-DELCO 601177, EARLY CHEVY SCH service manual (1st page)
Preview of UNITED MOTORS SERVICE-DELCO 601177, EARLY CHEVY SCH [1st page]
UNITED MOTORS SERVICE-DELCO 601177, EARLY CHEVY SCH service manual (2nd page)
Preview of UNITED MOTORS SERVICE-DELCO 601177, EARLY CHEVY SCH [2nd page]
    UNITED MOTORS EARLY CHEVY 601177 DELCO
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Harman Kardon HKTS-11 sub auto standby hiba Megoldva!
Ismét hozzám került egy harman sub, amit sikeresen újraélesztettem, a sub tökéletesen működik.
Viszont még olyan "hibája" van, hogy nem hajlandó kikapcsolni mikor auto standy- módban van.Szinte az összes kondit cseréltem már benne, de órák múlva is bekapcsolva marad, holott elvileg max fél óra után ki kellene hogy kapcsoljon.
Esetleg valaki tapasztalt valami hasonlót?
A sub újra a régi, az u203 cseréje után kb 18 perc tétlenség után standby üzemmódba lép.
Pioneer alkatrész beszerzési pályája kinek van?(megoldva)
Sziasztok, Szükségem lenne néhány pioneer alkatrész beszerzési lehetőségeire és árára. A gép cdj350, és az alkatrészek cikkszáma:DNK5549(control panel),DAH2789(display panel),DAC2580(play button),DNK5657(usb cover),DSG1079(tact switch),dsg1117(tact switch). Írhattok ide is és a mailcímemre is. Előre is köszönöm. üdv András Köszönöm a segítségeket és az ötleteket, megkaptam a magyar importörtől a teljesen elfogadható forintosított árakat, így tőlük beszerzem a dolgokat.
Sencor autóhangszórók, vélemény?
Sziasztok! Vásárlás előtt szondázom a piacot :) Van gyakrolati tapasztalatotok a Sencor hangszórókról? Hasonló kategóriában kapható JVC, Sony is (szerényebb műszaki paraméterrel, kicsit drágábban). Vélemények? Természetesen nem Audiofil hangzást szeretnék varázsolni 15 éves autómba :D Csak a gyári 6W-os hangszórókat szeretném kicsit modernizálni... http://www.sencor.co.hu/auto-hifi/hangszorok.aspx
