USSR C1-108 S1-108 OSCILLOSCOPE SCH
METER - SERVICE MANUAL
2.0 MB
METER
Looking for similar ussr manual?
    USSR C-1108 C1108 S1108 1108 C1 108 S1 C1-108 S1-108
Relevant METER forum topics:
Pixelated Readout Hameg 404-2
Hello,
I purchased a Hameg 404-2. It works normally as an analog scope. But what doesn't work is the readout, the display of the numbers and letters on the screen. These are pixelated. I have restored several vintage scopes (Hameg, Tektronix, Leader) but have no experience with this type of scope. Where can I suspect the error, which module is in question? What is the procedure? There is a circuit diagram, but it doesn't really help me. I checked the supply voltages and everything was spot on. Can someone help me? Thank you.
fluke 123
sziasztok.van egy ilyen kis műszerem ,amiben ez az smd alkatrész szált el P43 ,vajon mi lehet ez?
Ganzuniv 3-asnál miért dugnak műanyag dugót a 10 A-es banánhüvely-csatlakozóba?
Ha csak egynél láttam volna, azt mondom véletlen, na de már nem először látok ilyet! Van valakinek racionális magyarázata arra, hogy miért csinál valaki ilyet?
Looking for Metrix MX53 Multimeter schematic
Hi there,
After many years of good services, I made a mistake while measuring UHV (ultra high voltagel with my  METRIX MX53) . I was measuring a voltage around 2500V DC with all the safety required, using a divider, to get only 1/50th of the voltage as I did many times.
But for some unknown reasons (I'm rarely distracted when playing with such letal voltage) , I didn't connect my clip at the divider but at the full voltage.
You understand that the MX53 didn't appreciate it.
I opened the multimeter, which is kind of sport as not as easy as it looks and found a resistor R1 (may be 200 ohms 5%, hard to read) completely exploded. I replaced it. I also found that 2 of the four varistors were shorted, changed them, I checked all the transistors, mostly SMD, but they all look fine as far as I can see. However, the multimeter is still not responding.
I have also found 2 SMD diodes that could also be shorted and need to check them more thoroughly...
I have very few chances to fix the meter but if I could put my hand on its schematic, It would be easier to track down the culprit, hoping it's not the proprietary chip in it.
So, if someone have (or could lead me to a link to it) the circuit drawing of the MX53, preferably, or the MX52 or MX54 which look close to it, just a few functions more and the PCB looks common to both as the MX53 has some locations not populated with components, it would help me to try to save my old companion!
Thanks in advance, any help much appreciated.!
Nota: METRIX is a French company, was also know as Chauvin-Arnoux.
Regards from France...!
