USSR TERNAVA 302.
68.4 KB
Looking for similar ussr manual?
    USSR TERNAVA 302. 302
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
CROWN PS-K150 magnós rádió
Sziasztok. A fenti kétkazettás rádió-magnót javítom.Az a hibája, hogy a kazettát min. kétszeres sebességgel játssza le. Mi lehet a kínja neki? A motorra 4 derót megy. Olyan mintha nagy sebességű másolásnál(hi speed dubbing) hallgatnám, de ennek a kapcsolója jó és ki/be kapcsolva is ugyanilyen gyors.Ha valakinek van rajza róla légyszi küldje el. Köszi.
Eladó ORBITECH CI400CRCS digitális műholdas beltéri ,UPC DIREKT vételére ideális!
Eladó ORBITECH CI400CRCS digitális műholdas beltéri egység conax és cryptoworks kártyaolvasóval.UPC DIREKT vételére ideális! Gyári távirányító nincs a készülékhez,én SilverCrest univerzális és gombhelyes távval használtam,amit a LIDL áruházba vettem. Ár:3000Ft
Quad 405-höz hangszínszabályzó készítése
Sziasztok! Tudna valaki valamit ajánlani? Nyákterv sem lenne rossz. Be kéne már végre fejeznem... Köszönöm!
