I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
sziasztok,
Egy barátomnak (unokatestvér) van egy ilyen "erősítője", és egy szerviz elutasította a javítását...
"processzor hiba"...
Azt kérdezte tőlem, hogy újat kell-e vennie, vagy van esetleg valaki, aki foglalkozna vele...
Budapest / Sárosapatak / Miskolc vonzáskörzetében...
Azt mondta, "erősítő", ezért egyből rávágtam, hogy nincs olyan, hogy ne lehetne megjavítani...
de amint látom a user manual-t (per elektrotanya), egy bazi komplex cucc....
Szóval, azt szeretném kérdezni, hogy valaki elvállaná-e a javítását?
köszönet,
Jósvai Péter
PS:
az észlelt hiba:
"a hangerő szabályzója rossz... hiába tekerem, nem csinál semmit"
"egy szervizben azt mondták, processzor hiba"
yamaha R-700 rádióserösitő rajzát keresem vagy legalább anyi infót hogy, a végfok
müveleti erösitőjének mi a száma ,mert valaki kiszerelte és nincs meg.továbbá pioneer GM3000 auterösitő rajza,és technics su-8 erösitő rajza kellene .előre is köszönöm!
A címben említett típusú erősítő 1 sec után visszatér STAND-BY-ba.
A DIAG mode megy, és ezt a hibát dobja : PS PRT 21 C
Az biztos, hogy úgy lett bekapcsolva, hogy az impedancia választó középen volt (kölcsön volt adva). Átállítottam normál-ba (8Ohm), de nem változott semmi.
Szerintetek végfok lehet a gond ? Ahogy nézem a 21-es érték rossz, mert 28-43-ig kellene lennie.
Előre is köszönöm
