SONY kv-m2100d_white picture Solved
14 posts / 0 new
JIMMY20
JIMMY20 picture
hello my friends!
i have a tv sony with this problem:it has got sound and white picture.ihave got the 200vin the tv board,i replace the capacitor 10μf/250v and the Q703,706,709 its ok.i want to check the tda3508 but i dont found in the greek market maybe the problem was here
can you help me what can i check?
thank you very much!
JIMMY20
JIMMY20 picture
kolya61!! was wright my friend you are the best, the problem solved,i changed D504 and it works ok!!
thanks for all my friend and all other friends for the information
kolya61
kolya61 picture
Szia JIMMY!
You're welcome!
I'm glad you helped you a replacement. :super:
Üdv! Miki.
JIMMY20
JIMMY20 picture
hi!
kolya61, thank you very much for your information i'll repair d504.
best wishes
JIMMY20
JIMMY20 picture
HI!!
thanks for all my friend, i 'll checked this that you said.
best wishes
kolya61
kolya61 picture
Szia JIMMY!
Chassis BE-2A.
A D504 -et cserélted már?
Nem mérni, cserélni !
Hi, Jimmy!
Chassis BE-2A.
The D504 has changed?
Not measured, replace!
Kalex-nek ! :bow:
Üdv! Miki.
city217
city217 picture
Hi!
And I already thought you had committed. -mosolyog-
Kalex
Kalex picture
"And I already thought you had committed."
To believe the church should be! This is an exact profession. =vigyor=
Üdv! Kalex
Tvguru
Tvguru picture
Hali!
Pozíciószámot így nem tudok "mondani", de a sorki "alatt" egy smd dióda a hunyó.
tvguru
Kari
Kari picture
Hi Jimmy!
Kolya told for you(ID:114381): you can search for TDA3505 or TDA3506 too, because they workes good in a KV-M1400K...
Regards-Kari
kolya61
kolya61 picture
Szia Karesz!
Thank you, very much! :bow:
Üdv! Miki.
JIMMY20
JIMMY20 picture
you believe that the problem was in the tda3508?
thank you!
Kalex
Kalex picture
Hello Jimmy!
The requested it can be found in IC.
Best wishes! Kalex
kolya61
kolya61 picture
Szia Kalex!
Fordítsd le légyszíves Jimmy-nek, hogy próbáljon akkor TDA3505, vagy TDA3506 bele rakni , ha talál ilyeneket. KV-M1400K -ban müködik :D
Üdv! Miki.
