hello my friends!
i have a tv sony with this problem:it has got sound and white picture.ihave got the 200vin the tv board,i replace the capacitor 10μf/250v and the Q703,706,709 its ok.i want to check the tda3508 but i dont found in the greek market maybe the problem was here
can you help me what can i check?
thank you very much!
2012, January 15 - 16:49
#1
kolya61!! was wright my friend you are the best, the problem solved,i changed D504 and it works ok!!
thanks for all my friend and all other friends for the information
Szia JIMMY!
You're welcome!
I'm glad you helped you a replacement. :super:
Üdv! Miki.
hi!
kolya61, thank you very much for your information i'll repair d504.
best wishes
HI!!
thanks for all my friend, i 'll checked this that you said.
best wishes
Szia JIMMY!
Chassis BE-2A.
A D504 -et cserélted már?
Nem mérni, cserélni !
Hi, Jimmy!
Chassis BE-2A.
The D504 has changed?
Not measured, replace!
Kalex-nek ! :bow:
Üdv! Miki.
Hi!
And I already thought you had committed. -mosolyog-
"And I already thought you had committed."
To believe the church should be! This is an exact profession. =vigyor=
Üdv! Kalex
Hali!
Pozíciószámot így nem tudok "mondani", de a sorki "alatt" egy smd dióda a hunyó.
tvguru
Hi Jimmy!
Kolya told for you(ID:114381): you can search for TDA3505 or TDA3506 too, because they workes good in a KV-M1400K...
Regards-Kari
Szia Karesz!
Thank you, very much! :bow:
Üdv! Miki.
you believe that the problem was in the tda3508?
thank you!
Hello Jimmy!
The requested it can be found in IC.
Best wishes! Kalex
Szia Kalex!
Fordítsd le légyszíves Jimmy-nek, hogy próbáljon akkor TDA3505, vagy TDA3506 bele rakni , ha talál ilyeneket. KV-M1400K -ban müködik :D
Üdv! Miki.
