AKAI CT-2119 CTV Test Mode
Simultaneous press + & - on local panel and then power on with main switch.
Exit:POWER.
Allstar 3750 CTV Hotel Mode
OFF: Select program 38. Simultaneous press (3 sec) STORE & CONTROL+ on local keyboard.
ON: Select program 38. Simultaneous press (3 sec) STORE & PROGRAM- on local keyboard.
AudioTon CTV 5502 10.3 90° MONO CTV Child Lock Clear
Press UP & DOWN buttons together on tv's local control and then switch on. You will see SERVICE MODE. Do not press any button, just power off the set, then on.
AudioTon CTV 5502 10.3 90° MONO CTV Service Mode
Beko CTV Service Mode
Simultaneous press P+ & P- on local panel and then power on with main switch.
Blaupunkt MM63-13VT FM240.00 CTV ATS
Press button P/C on RC and switch on TV with main switch.
Blaupunkt MM63-13VT FM240.00 CTV Hotel Mode Cancel
Press button 'i' on RC and switch on TV with main switch.
Brandt ICC9 CTV Service Mode Switch off TV with RC (st-by).
Switch off TV with main switch. Wait a few sec till ST_BY LED
switch off: Simultaneous press VT button on RC and switch on TV with main switch. Press VT button again. WARNING: scart must be free.
Continental CT1412B CTV Service Mode
Press and hold P+ and P- on local panel, then switch on TV with main switch.
Ferguson ICC9 CTV Service Mode Switch off TV with RC (st-by).
switch off: Simultaneous press VT button on RC and switch on TV with main switch. Press VT button again. (WARNING: scart must be free.)
Ferguson TX92 CTV Hotel Mode Cancel
Put TV into standby, then turn power off, then turn power on whilst holding standby button on remote and step through menus to vol set and increase level to max.
Finlux 17/21B60 63/71Y2 STEREO PLUS CTV Service Mode
MUTE --> OK (M) --> TV
Controls: cursor buttons.
Store: OK (M).
Exit: TV
Goldstar MC-51B CTV Service Mode
Simultaneously press MENU, VOL-, PR- on the local panel.
Graetz BURGGRAF STEREO 4876 Digivision DIGI III 110° CTV Service Mode
Turn on 'TV Internal Service Program' switch on the digital modul (SE on display).
On RC: 1=U1 V SHIFT, 2=U2 V LIN DN, 3=U3 V LIN, 4=H1 H SHIFT, 5=H2 H AMP, 6=H3 EW AMP, 7= C, 8=C1, 9=C2, 0=H4 EW TRAPEZ... TV=MEMO, VOL+/-=ADJUST.
TV szervizkódok vegyesen: http://www.tvservicemenu.com/
VIDEOCON Challenger Dlx TV
Models: 3634R,5134R,5443-R
For entering into Service Mode:
· Short contacts of the hidden SERVICE key inside the remote handset.
· After getting the screen of “SERVICES” press desired numeric key (“0”, “1”, “2”, “3”, “4”, “5”, “6”) to go into that menu.
· To enter into Service Mode, press numeric button “1”
· To enter into Design Mode, press numeric button “2”
· To enter Factory Shipping Mode, Press numeric button “3”
· To enter into Manufacturing Mode press numeric button “4”
· To access any parameter, use Up/Dn Keys of Program /Channel
· To change value of any parameter, use +/- keys of volume
· To exit, again short contacts of hidden Service Key or switch off the set into standby
SANSUI/VIDEOCON TV
Models: SV-2012,SV-1412/5136-R
· Short contacts of the hidden SERVICE key Inside the remote handset
“TEST” will appear on the screen.
· Now, Press numeric keys ( “1”, “2”, “3”, “4”, “5”, “6”, “7”, “8”, “9” & “0” ) on the remote handset to get the various service menus.
· Note that menu no. 3,4 & 5 are general menus while menu no.1,2,6,7,8,9 & 0 are special menus. To access these menu enter special code “991220” when “TEST” appears on the screen.
· To access any parameter , use Up/Dn keys of Program/Channel
· To change value of any Parameter, use +/- keys of Volume
· To exit , again short contacts of hidden Service key or switch off the set into Standby
PHILIPS UOC Kit
· First Press ‘MENU’ button and numeric key “1147” on the remote handset to get the various service menus.
TCL TV
Model: T2111A
· Simultaneously press “DISPLAY” button on remote handset and Volume- button on the front panel of television receiver for 6 to 8 seconds to get the various service menus.
· To exit POWER switch off the set
SONY TV SERVICE MENUS
Models:
KL-37W1U KL-50W1U KL-50W2U LE-1 chassis
To enter the service mode:
Turn the mains power on while holding the "PROG +" and the "PROG -"
buttons on the set simultaneously.
"TT" will appear at the top right hand corner of the screen
Press "01" on the remote control to see the service menu on screen
Press the "arrow up" and the "arrow down" buttons on the remote
control to navigate the menus
Press the "OK" button to select an adjustment
Press the "arrow up" and the "arrow down" buttons to highlight an
adjustment, and press the "OK" button to allow adjustment.
Use the "arrow up" and the "arrow down" buttons to adjust the value
Press the "OK" button to store
Turn off the power to exit the service mode
Test mode 2 allows entry of TT numbers to perform some functions. The
important numbers for this chassis are given below
TT00 switch the TT mode off
TT08 set the set to shipping condition
TT15 Factory reset values
TT16 User defined reset values
TT16 loads the contents of the NVM when the set was last switched off
TT15 loads the factory defaults. To do this press TT15 followed by
TT16.
Models:
KV25F1U - KV29F1U - KV25F2U - KV29F2U - KV25F3U - KV29F3U -
KV25X1U - KV29X1U - KV24WX1U - KV28WX1U - KV24WS2U - KN28WS2U -
KV28WF1U - KV32WF1U - KV29FX11U - BE-3D chassis
KV28DS20U KV28DX20U KV32DS20U KV32DX20U BE-3E chassis
To access the service mode:
Turn the set on and then put into standby
Press the On Screen Display button
Press the "5" button
Press the "VOLUME +" button
Press the "TV" button
Press the "MENU" button on the remote control to bring up the test
screen
Use the joystick on the remote control to navigate the service menu
(< > ^ v keys BE-3E)
Press the right joystick to enter the selected adjustment
Turn off the power to store and exit the service mode
TT24 Set CTV to UK model (PAL I)
TT44 Set all favourite pages to 100
To re-initialise the NV Ram follow the procedure below:
Set the TV to channel 59
Select TT49
Switch off at the mains supply, wait for one minute and switch the
set back on
Select channel 59, and enter the service mode
Select TT24, (UK destination)
Select TT42, (general reset)
Switch off at the mains, wait for one minute and switch on again
Auto tune the channels and carry out a complete adjustment on the set
Models KP-41S3U RE-1 chassis
Use buttons "1" and "4" on the remote control to navigate the service
menu
Use buttons "3" and "6" to adjust the selected data
Press the "MUTE" button and then the "0" button to store the data
Press the "5" button and then the "0" button to initialise the set.
(Note, this is an extreme measure and should be used with caution!)
Turn the set off to exit
Models:
menu
Models:
KP-41DS1U RE-2D chassis
Use the JOYSTICK Up / Down on the remote control to navigate the
service menu
Move the JOYSTICK to the right > to enter the selected adjustment
Press OK on the JOYSTICK to EXIT
Press the "MUTE" button and then the "0" button to write data
Press the "On Screen Display" button to copy data
Turn the set off to quit the service mode when adjustments are
complete
Models:
KV-14V4U TE-1 chassis
menu
The codes on screen are as follows:
ODL Power On Delay
OSH On screen H-position
MUT FTZ muting on *Do not adjust
VAM V. size
VBC V breath correct *Do not adjust
PAM Parabola amp. *Do not adjust
PTI Parabola tilt *Do not adjust
VLI V-linearity
CCR Corner correction *Do not adjust
HAM V. cent *Do not adjust
BIN Blue intensity
GIN Green intensity
RIN Red intensity
CLS Colour system
SCO Sub contrast
SBR Sub brightness
SSA Sub saturation
SHU Sub hue
SSH Sub sharpness
G2 adj G2 adjustment
32K adj
Models:
KV-16WS1U KV-21X1U KV-21X4U KV-20WS1U BE-5 chassis
Press the "MENU" button on the remote control to see the service menu
on screen
Use the "blue" button and the "green" button on the remote control to
Use the "Yellow" button and the "red" button to adjust the selected
data
Turn the set off to exit and store
TT26 Set CTV to UK model (PAL I)
TT41 Re-initialise NVM
TT43 Re-initialise geometry settings
Note: For TT numbers above 41, the channel number needs to be 59
Models:
KV-32WS4U KV32WX4U KV32WX2U AE-4 chassis
"TT" will appear on the top right hand corner of the screen.
Press "MENU" on the remote control to get the service menu on screen
Navigate the menu by moving the joystick up and down.(green and blue)
Press the joystick down to select an adjustment.
Turn TV off to exit service mode
TT00,10,20,30,40 pressing these numbers will switch the TT mode
off
TT01 switch service menu on
TT21 picture rotation automatic function
TT25 Status menu display
TT49 New initialisation
Models:
KV28FD1E KV28FD1K KV32FD1E KV32FD1K GE-1 chassis
The main adjustments are:
MCP CXA2101 - picture (colour, drives, brightness etc)
Deflection control SDA9361 - geometry
Models:
KV-29X5U FE-1 chassis
Use buttons "^"(Green) and "v"(Blue) on the remote control to
Press YELLOW button to enter required menu
Use buttons "<" and ">" to adjust the selected data
Press the "MENU" button to store the data and exit
Test Menu
Picture - (RGB. Drives & Cut offs, Sub Colour, Sub brightness)
Geometry - (Vert. and Horiz. adjustments)
Sound - (NICAM Information)
TV Status - (Destination and Country info.)
AGC. Adjust
Technical
Philips és Beko Tv-k szervizmenü és opciók
11AK19 service menu és beállítás
11AK37 service menu és beállítás
Ha te is ismersz hasznos unlock kódokat, írd be ide, vagy nyiss neki egy új fórumtémát (pl. azonos márkán belül több kód).
Ezeket egy cseh oldalon találtam. Sajnos majdnem mind cseh nyelven van, de majd a google talán lefordítja.....
