Hay
i m using DC invert welding machine since last 3 year, but now it give electric shock during weld, what's problem any one help me, or how I check, machine name is SMATO H160
Waiting for reply
What exactly are you doing when it shocks? Touching the case, the electrode, the workpiece or the connections? Or two of them at the same time? Are you wearing gloves? Have you checked the protecting earth wire (ohm meter between the case and the mains connector earth)? Have you tried to use the machine in different buildings? (Wiring problems of the building)
While touch work get shock
While touching the work get shock and also tester is glow at negative terminal of welding machine.
