Yamaha RX-V683 unequal right and left fort channels
Hi,
In my RX V683 BL the front left channel seems to be 2db louder than frint right.
is there ant resistive pot in the amp section where one can adjust this.
kindly advise
regards,
are you sure your speakers are correctly levelled? means: does this effect appear also if you switch left with right speaker?
did you try the level adjustment first? since the early days of AVR you can adjust each channel separately. https://youtu.be/olDfPWtLR7c?t=423
if you consider stereo playback, you might want to use the use "balance" function to look like this " L <-----------II------> R "
Now it is cold and bad weather, may it be you have some cold/sneeze which is affecting your ears? Do not laugh too hard, I had one friend of mine, who really had this issue ;)
Kind regards.
