led modelo tcl32x30a..al encender titila una vez,podria alguien decirme como puedo reparar la falla Panasonic led tv model tcl32x30a. Flashing once. Could someone tell me how I can repair the fault? Add new comment Comments 2020, May 30 - 13:03 #440960 Jon Snell 7 years 3 months The fault is within the A or main board. There are a number of causes, from a BGA re-flow required to power failure on the board. Most just replace the A board. 0 2020, May 30 - 13:19 [Jon Snell: #440960] #440962 Mykola Visitor Hi Jon, when you have received flash error #1 - it means that back-light is fault. You should check back lighting circuit. 0
