What mean this 6 times blinking ?
no picture on Screen;
no sounds;
no backlight;
on powersupply the power for backlight is 250V on 2 blue cables;
5V is (5.2V) on and 13V are only 12.88 V
what are the Problem ?
I think backlight LED are defektive and on powersupply the 13V are not ok.
Must I change the powersupply ?
HI! Try the tv start without main board. You must see the backlight on the screen. If you does not have backlight, then replace wrong led.
Hello! The Samsung TV-s have not blinking error codes.
