What does switch do?
Hi you all,
thank you for the opportunity to ask questions.
I have a schematic of a switch but I don't know the symbol. It is a push button with 6 contacts.
As I cannot upload a drawing, I'll try to recreate it.
0 0
0 || 0
0 || 0
The 6 '0' are the contact points.
The left and right | of the upper || and lower || are connected continuously. So one long | left and one long | right over the height of the lower two rows of contacts.
Thanks!
Bart
Bart
Bart picture
Hi,
thank you all for your help.
This is a link to the part of the scheme containing the switch: https://ibb.co/f8mhR6N
Which wires will be connected when putting the switch in the 'on' position?
Thank you!
Bart
imrus101
imrus101 picture
1 -O  O- 4
2 -O||O- 5
3 -O||O- 6
It is a DPDT switch. There are two independent switches, that are mechanically connected. If we suppose that the OFF state is shown in the schematic you linked, then pins 2 and 3 connected on the left side and pins 5 and 6 on the right side. If we throw the switch to ON state then pin 1 connected to pin 2 and pin 4 to pin 5.
imrus101
Bart
Bart picture
Hi imrus101,
thank you so much.
So the full story. My multimeter on/off push button broke down. So I ordered a new one, soldered it, but the multimeter doesn't work. I tried several obvious checks but no luck. Maybe I used the wrong switch? Before desoldering I'd like your opinion.
This is the whole schematic (top left is the  switch): https://elektrotanya.com/my-64_digital_multimeter_sch.pdf/download.html
This is the schematic of the switch I bought: https://robu.in/product/7x7mm-6-pin-dpdt-self-lock-lock-push-switch-10pcs or a direct link: https://aws.robu.in/wp-content/uploads/2019/11/7x7mm-6-Pin-DPDT-Self-Loc... (They were advertised specifically for multimeters).
Many thanks, for everybody's help.
PS: I tried to click a thumbs up, but nothing happens.
Jaca
Jaca picture
Hi Bart,
Could You send a pic from the PCB, booth side, around the switch holes, without the switch.
Regards,
Jacint
Kalex
Kalex picture
Hi!
Take a photo and upload it to an image sharer. Copy the link. Maybe we can help.
Kalex
Bart
Bart picture
It seems the right '0' has shifted to the middle in my 'drawing'. Left and right there should be a row of 3 aligned contact points ('0's).
Bart
PElek
PElek picture
Try to use and measure with an DVM diode and voice test measurement.
Then share the results.
Bart
Bart picture
Hi Pelek,
it is a schematic.
And even if it was a physical board, I would not understand what you mean. I'm new at all this.
Thanks.
