SHARP SJX-640-MG3 side by side refrigerator is making loud noise
Hello out there on the cloud
since 5am this morning my sharp SJX-640-MG3 side by side freezer refrigerator is making a very loud noise
the motor seems to be switching on and off more often than usual
The display says E4
When I purchased it 2 years ago I was given no instruction manual with error codes and the ones i found on internet are not the same : there is no E4
i have tried :
.  checking  with a tester if there is an electric contact
. putting fridge in an other electric socket
. checking level
. checking if air vent is blocked in freezer and fridge
. checking if doors close properly
. checking temperature ( freezer says -16c & fridge -2C )
it still makes the same « clonck » noise when compressor starts and continues with a loud snore ..
we are totally confined in a small house and have to listen to this horrible noise
thank you for your help  !
jackie
Вадим Фомин
Вадим Фомин picture
две причины
1 вышло из строя тепловое(Пусковое) реле- замена пускового реле(установлено прямо на двигателе)
2 сгорела обмотка электродвигателя пуска в компрессоре- мотор под замену капитальный ремонт
