17IPS62 power supply, stand by ic i can’t find another to replace
Hi dear friends,
i have some bad tv and after thunderstorm power supply died i check and found that stand by ic is bad,
Board is (17IPS62) power supply.
I found that U1 ic is bad but unfortunately on ic no part number just 10001 which is not enough for me to find new standby ic.
does anyone has idea which ic is u1 on board?
F-Yoci
F-Yoci picture
Hi!
The 1Q001 not equal 100% with the FAN6300 !!!
Order the original BM1Q001 type. ASWO code: #G129432
Balázs
Balázs picture
Hi
1Q001 the ic type. Fan6300
Balázs
uniman
uniman picture
 "Fan 6300 nem jó bele.(Csak átalakítással)" :
https://elektrotanya.com/comment/457674#comment-457674
Bár itt is a 6300 IC  lett először megnevezve, de kdierült, hogy az U1 ic (BM)1Q001.
BM1Q001 IC datasheet
