I recently bought a Videonics Mxpro and it didnt come with a power cord and from my research im learning I need a 8 Pin 270 degree DIN cord, but the problem is these are discontinued,
So ive tried to connect a 6 pin din cord to it with careful pin match up using extra wires.
from the +5V to the (what I believe is the) MXpro's +5V pin on the female end.
and the ground from the ac adapter to the ground on the MXpro
and NO LUCK,
ANY help is appreciated as to how I can get this baby some power to start working,
if anyone knows about vintage electronics or 8 Pin DIN power supplies I would LOVE any insight, Thank you
try it:
https://uk.farnell.com/search?st=din%208%20pin%20plug
Hi,
For example:
https://www.google.com/search?q=8+t%C5%B1s+270+fokos+din&sxsrf=AOaemvKI3...
https://shophu.kingsgu.ru/content?c=9%20t%C5%B1s%20din%20csatlakoz%C3%B3...
