Spice model for the NPN 2SC2498
12 posts / 0 new
rjcamatos
rjcamatos picture
Sirs,
Im looking for a Spice model of the BJT 2SC2498, until now i got one model that it says its compatible, but, in ltspice works as expected, but in reality it didn't work.
Some one can indicate me where i can find that model?
Google didn't help.
Gita
Gita picture
https://elcodis.com/parts/6153360/2sc2498.html      Attached and datasheet.
rjcamatos
rjcamatos picture
.MODEL 2SC2498  NPN (IS=1.55467e-17 BF=296.182 NF=0.850014 VAF=10
+IKF=0.00544635 ISE=2.01913e-14 NE=1.54276 BR=19.550
+NR=0.825166 VAR=73.1109 IKR=0.0544635 ISC=1e-160
+NC=2.9688 RB=21.0221 IRB=0.478136 RBM=0.1384250
+RE=0.000646335 RC=3.0552 XTB=0.582018 XTI=1
+EG=1.06135 CJE=1.08982e-12 VJE=0.99 MJE=0.230
+TF=2.15066e-11 XTF=1000 VTF=1.33967 ITF=0.0010
+CJC=1.89423e-12 VJC=0.95 MJC=0.23 XCJC=0.4084790
+FC=0.1 CJS=0 VJS=0.75 MJS=0.50
+TR=1e-07 PTF=0 KF=0 AF=1)
AzzA
AzzA picture
Hi rjcamatos,
If you can't find a solution to the problem, do try with the Labcenter Proteus circuit simulations
regards,
rjcamatos
rjcamatos picture
Tanks for sugestion, but most of Spice software does not have models for VHF/UHF components.
O try to search for that model and compatibles but it looks like missing of VHF/UHF models.
AzzA
AzzA picture
Hi,
I see they are looking for spice UHF model on the many forums but few can be found.
Ferenc.P
Ferenc.P picture
Hi!
PSpice library (old Release 9.2, for example) contains the model of the transistor you are looking for (page 231)
or create Your own model: https://www.youspice.com/spice-modeling-of-a-bjt-from-datasheet/
File csatolás:
rjcamatos
rjcamatos picture
Tanks,
But there is a problem, the datasheet does not describ all the required parameters!
Ferenc.P
Ferenc.P picture
Hi: If the model not found on the manufacturer's site then the reliability of the model is always in question. I found these three types "side by side". Both models can be found on the net.
The compatible types - let me attach them too:
Regards,
rjcamatos
rjcamatos picture
Tank you very mutch, this models are complet difrent from the one that i have, hope so that the LTSpice simulation Will BE similar to the prototype circuit that i made.
Go on testing :)
Good Hollydays
zsugori
zsugori picture
