Hello,
Trying to get a replacement part which is this ceramic cap.
Does anyone know the value (uF and voltage) of this cap?
Many thanks.
Ray
Hello,
Many thanks.
Ray
Hello!
Are you sure it's a capacitor?
Polyfuse is also produced in such a case.
What do you measure on the two terminals?
Regards, Tony
Pardon my ignorance!
I believe you are right. It should be a polyfuse and not a capacitor.
I think if tested lead to lead, it should have continuity then. For a while, I was wondering if this should be replaced.
Guess not!
Thanks!
