Sir,
Im trying to find the datasheet of the RD8P01CS1002, where can i get it?
can't find online!
2022, January 10 - 03:23
#1
Sir,
can't find online!
mibe lehet
You voted ‘up’
Ok i think i get it....
is the https://ixapps.ixys.com/DataSheet/S3F8S28_S3F8S24PB.pdf
You voted ‘up’
ok
You voted ‘up’
Talking on another fórum they tell me that if it have no Transformers on the input they tell me they 230V have a type of capacitor dropper to drop to 5V the main power.
The IC is probably of the family that you told me.
Tankyou very mutch.
Best Regards,
Ricardo Matos.
You voted ‘up’
The circuit board...
it recives as input 230V AC.
It is described as new sensor relay in seels, and its realy an ic relay with a counter and a thermostat!
Not a fancy 5Volt MCU.
Ho will put and mcu on a toaster? It was for comunication with the phone to tell the bred was ready?
You voted ‘up’
Looking better and think is not that one you mention, the model:
HT46R46 / HT46C46 / HT46R47 / HT46C47
20 SSOP - A
You voted ‘up’
l toke a look of the following devices, but power pins does not match.
You voted ‘up’
By the way there are no oscilador and it don't have an internal oscilador.
You voted ‘up’
Tanks, but .... not that one.
You voted ‘up’
