Relay needed
10 posts / 0 new
bob54
bob54 picture
I Have a Sony STR-V55 stereo receiver and need a relay for it. It is 24 volt and the Soney part number is 1-515-347-00. RY801 on the schematic. Can anyone give me an idea how to cross reference the Sony part number? I am not having much luck finding it on line.
Thanks
Kari
Kari picture
Hi Bob,
Do you have pls some coding/type number, printed text etc., on these relay?
Can you give us some more details knowed over your real examplar pls',
maybe a photo and footprint -or so?
Greetings,
Kari
bob54
bob54 picture
Waiting to hear back from Sony. Markings on the relay "type AP" "24dc 1U" "DEC"
"302 Japan" No other markings, batt dead in the camera so I'll post photos tomorrow
The schematic is here
https://acrobat.com/?i=feCTveQtZ-Bf8QsFfCKWXg
It is RY801 on the "Power Amp Board" Right side about mid way down Between I&J at #3 page 22
Kari
Kari picture
Hi Bob,
Sorry, but I do belive, that you must/can forget the Sony spares for a ca. 30 years old equipment... :-(
Otherweise; can you tell me the measures of these relay please?
If Im right, it must be so ca. 30x16mm, but what is the possible hight pls?
Some moderner products are surly not so relative big as these original one, and Im on the searching for similar exemplare/type with an applicable footprint :-)...
Greetings,
Kari
SzBálint
SzBálint picture
Kari
Kari picture
Szia Balint!
A katalogust köszi!_a gond annyi, hogy 1:1 megfelelö nincsen, de ezek meg mind kissebb alapterület igenyüek is...
Persze nem gond a labakat kisse szethajlitani, de kerdes, hogy ezt a joember is igy latja-e?
No, meg azert keresgetek...
Hallo Bob,
from attached Tyco types are two(RPII/2 & RX2) relative god to use, but they are (of course) not 100% the same on the footprint_as I did assumed...
I will search for others too.
Kari
bob54
bob54 picture
Could not find my Metric ruler so here it is in inches 1 1/4 long, 9/16 wide and 1 1/16 tall. I figured if I can't match the foot print I could hot glue the relay on the board upside down and then wire it.
Kari
Kari picture
Hi Bob,
OK, 1 1/4 long, 9/16 wide and 1 1/16 tall ae inmetric system: 31,75x14,3x25,5mm.
I would propose for you both following Tyco relays to check for your replacement:
RPII/2,or RP420024, is ca. 25.5mm high,Cd ordering code/part Nr. for 24V DC: 5-1393234-1
RPII/2,or RP421024, is ca. 25.5mm high,Ni ordering code/part Nr. for 24V DC: 6-1393234-8
http://octopart.com/partsearch/#search/requestData&q=5-1393234-1+tyco(i.e. Arrow has it:$3.70)
http://octopart.com/partsearch/#search/requestData&q=6-1393234-8+tyco(Onlinecomp. has it:$3.10)
RXII,or RX420024(event.C), is ca. 16mm high, ordering code/part Nr. for 24V DC: 3-1415504-1
RXII, as transparant version; RX420024C, part Nr. for 24V DC: 6-1415504-1
Use pls pins 11/14 or 21/24, evetually both parallel: 11,21 & 14/24.
The other pins, 12,22;_I would cut out...
In view of TOP are both footprints same as your PCB needs/has, but unfortunatly, the distances are some diferent, but with aplying of short soldered wire birdges; you can lightly adapt it.
Otherwise, what you need is not more as a good, industrie standard DC, power relay, then your mains current is max. at 2 Amps. They are practically all industrial types to use from ca. 4 Amps, typical for 6, 8, 10 or even 16 Ampers, the only question is a passable footprint...
If you are in the States, check pls //octopart.com for some surces, but in Europe is maybe Farnell the good source for you... In which country are you at home pls?
Best greetings!
Kari
bob54
bob54 picture
Illinois in the U.S. Thanks for all the help and info
Bob
Kari
Kari picture
Hi Bob,
Fein, tnx_far away, from EUropa & Hungary! :-)
You are welcome! :beer:
Good luck, by the preparation too :oke: !
Kari
