Sony STR DH130 protection mode
4 posts / 0 new
KVH
KVH picture
Friends Sony STR DH130 goes into protection mode soon after turning on.  It works for a second then can hear loud pops from speakers.
I've tried the suggested methods to fix but nothing works.  Correct impedance speakers.  Speakers wired correct.  Good ventilation.
I've tested the output transistors in circuit and I don't see anything unusual.  I may pull them to test but will wait for advice here.  I also measure
about 57 volts on the emitter resistors.  Seems high to me.  Anyone?
SzBálint
SzBálint picture
KVH
KVH picture
Thanks I've found them earlier and SM doesn't mention anything about protection kicking in
KVH
KVH picture
Problem fixed.  Bad solder joint on one of the filter caps.
