Friends Sony STR DH130 goes into protection mode soon after turning on. It works for a second then can hear loud pops from speakers.
I've tried the suggested methods to fix but nothing works. Correct impedance speakers. Speakers wired correct. Good ventilation.
I've tested the output transistors in circuit and I don't see anything unusual. I may pull them to test but will wait for advice here. I also measure
about 57 volts on the emitter resistors. Seems high to me. Anyone?
2022, July 28 - 17:09
#1
Hello: SM
https://elektrotanya.com/showresult?what=SONY%20STR%20DH130&kategoria=&k...
You voted ‘up’
Thanks I've found them earlier and SM doesn't mention anything about protection kicking in
You voted ‘up’
Problem fixed. Bad solder joint on one of the filter caps.
You voted ‘up’
