Cambiamos el CI STK 2038 y sigue el problema. Hay tensión continua +35V en la salida de bocina en Amplificador SU Z2 Technics. Gracias Add new comment Comments 2023, March 21 - 07:59 #512771 torokj 16 years 3 months Hello, https://elektrotanya.com/technics_su-z2_sch_2.pdf/download.html DId you check the -35 V negative voltage on the pin 4 of the SVISTK 2038?Also check the feedback resistors (R329-332) If the simmetrical power supply voltages are OK (+35V pin 2,-35V pin 4, you propably bought a FAKE power amp hybrid IC. TJ 0
Hello,
TJ
